Night render and moon shadows
Hi
I’m trying to create a simple night render.
I have set the GI Skylight to ACOLOR dark blue, multiplier 5.
And the background also to ACOLOR dark blue multiplier 1.
It looks ok, but I would like some sharp moon shadows. Does anyone know how to achive that ?
I’m I using a wrong method when I use ACOLOR ? could the same be done by using sky ? or do I have to use a V-Ray light ?
!(http://www.rattenborg.com/Download/VRay/20081105/Night test.jpg)
Re: Night render and moon shadows
anyone ?
What version of V-Ray are you using? With the Service Release you should be able to not have a Sky map in the Enviroment slot but still get SU sun shadows if you tick Default Light in Global Switches.
And have you tried setting the SU to a night time? Or reducing the multiplier of the SU sun?
just quick guess. how abou using omni and play with the multiplier. i do beleive ( if im not mistaken) the sun is a omni light…so i guess the moon should be the same
Thanks to you both. I’ll will experiment :slight_smile:
