no displacement..!!!!
hi guise,
i never tried displacement maps in my life,..i am satisfied by bump mapping..but now when i need displacement map i am not getting any displacement…!!!i tried all my knowledge’s but in vain ,…i am attaching all details of my try ,please somebody help me..
thank you.
this one with 100..!!edge length…
this one with 2 edge length…
you can see no difference…!!!
these are the settings i used please check…
here is render progress detail…
you can see no detailing about any displacement maps..!!! ???
Beginning render sequence
startCameraTime=0.000000, endCameraTime=0.033333
numCameraTMs=2, numFrames=1, frameSamples=2
Initializing built-in VFB.
Preparing camera sampler.
Preparing ray server.
Creating and initializing 2 thread(s).
Allocating memory for build data of 48161 faces (1348508 bytes, 1.3 MB).
Initializing face build data.
Creating ‘done’ event.
Starting first thread.
Waiting for thread completion.
Releasing thread resources.
Preparing faces for intersection tests.
SDTree statistics:
Total number of faces stored: 48161
Max tree depth: 37
Average tree depth: 23.0115
Number of tree nodes: 8542
Number of tree faces: 116022
Number of tree leafs: 3908
Average faces/leaf: 29.6883
Memory usage: 3.74 MB
Scene bounding box is [8.53157,15.2775,0]-[422.007,511.367,118.11]
Preparing direct light manager.
Preparing global light manager.
Irradiance sample size is 84 bytes
Photon size is 56 bytes.
Light cache sample size is 112 bytes.
Building light cache.
Tracing 1000000 image samples for light cache in 4 passes.
Setting up 2 thread(s)
Light cache time interval is (0.000000, 0.000000)
Bitmap file “C:\Documents and Settings\goutham\My Documents\BrickOldRounded0027_7_M2.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\Wood_Floor_Light.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\Textile_Floral2_White.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\Carpet_Pattern_Squares_Multi.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\Carpet_Frieze_Smoke.jpg” loaded.
Bitmap file “C:\Documents and Settings\goutham\My Documents\BrickGroutless0001_L 1.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\Isabel Vere.bmp” failed to load: cannot open file
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\Wood_Cherry_Original.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\Textile_Floral_Browns.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\Metal_Corrogated_Shiny.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\Firebook cover.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\Sketchy_Siding_Straight.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\Blinds_Roman_Hobbled_Red.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\cuento%20corto%20final252006.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\Textile_Leaves_Green.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\cuento.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\cuento%20interrumpido.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\Blinds_Roman_Hobbled_Blue.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\Blinds_Wood_Natural.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\Carpet_Berber_Pattern_Tan.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\images.jpg” loaded.
Bitmap file “C:\DOCUME~1\goutham\LOCALS~1\Temp\Untitled.jpg” loaded.
Threads completed
Merging light cache passes.
Light cache contains 18253 samples.
Light cache samples collected; compiling lookup tree.
Prefiltering light cache.
1 interpolation maps registered
Rendering interpolation maps with minRate=-3 and maxRate=0
Threads completed
Threads completed
Threads completed
Threads completed
Calling endPass() on irradiance maps
Calling prePassDone() on irradiance maps
Image prepass completed.
Rendering image.
Threads completed
Clearing global light manager.
Clearing direct light manager.
Clearing ray server.
Clearing geometry.
Clearing camera image sampler.
Clearing camera sampler.
Clearing QMC sampler.
Clearing path sampler.
Clearing color mapper.
Render completed
Re: no displacement..!!!
Did you group the geometry?
i didn’t understand… please explain…anyway i didn’t do anything like that…
thank you.
You have to isolate everything that you want to displace. Place the geometry inside a group or component. Do not apply any other material to the geometry inside that group or component.
ok…thank you, guise i will work on it… :smile:
