Recently I noticed I had no more vray properties when right-clicking on a geometry, only phoenixfd. So installed the latest vray and phoenixfd nightlies and now it’s the opposite, I don’t see the phoenixFD properties only the vray ones. I just reinstalled PhoenixFD to make sure and it’s still not there.
I use build 1512076523 2.2.5 nighlty (phoenixFD_adv_22050_max2016_vray_30_x64_26523) with vray_adv_33501_max2016_x64_26523 from yesterday
edit: I just noticed I can see the properties in the 3ds max object user defined properties box… is this normal?
I just reainstalled vray and phoenix with latest nightlies and I didn’t see the phoenixfd properties when right-clicking an object. I didn’t see them in the user properties neither.
But I could go in customize user interface and add the Display phoenixFd properties command in the quad menu!
Yes now everything is fine for me. Thanks Svetlin! It’s just that the installer don’t add the menu item in the right click quad menu anymore… But I had some trouble lately with my max menus. I think I installed too many beta plugins at the same time!
Yup, many plugins might have had it messed up. In fact - it’s the Phoenix dlr that adds the phoenix props to the right click menu on each startup, and it does that together with the maxscript functions, this is why I asked about them - if they are visible, then the menu must have been registered too, but something else prevented it from showing…
Since this happened to me too, I was able to experiment on it - my props in max 2016 were gone as well after my system crashed. For next week’s nightlies there will be a change that won’t allow the properties and particle export items to disappear like that
