noise bump wrong result. Does anyone have this problem?
I have asked this question before, but it has not been solved.
This is very serious.
I tested the A3 is correct, after the version is wrong.
I hope you can see the problem.
what’s wrong with the BUMP.
noise_test.c4d (368 KB)
your problem is caused by octaves>1, when trying to reduce your dent octaves from 5 to 1, the disorder is gone but with a different outcome of the noise ofc.. maybe you can just try and play around with different noisetextures/seeds/scaling to compensate..
i had tha same problem using a shader in glossy slot, maybe it due to c4d shader conversion…
I still get unusual results from bump, typically I use the filter shader to create a greyscale version of the texture I’m using for diffuse and I just don’t trust the outcome I get.
