as in the title, I’m rendering a short test (1080p). Outdoor, with grass and DOF.
After 50 passes (40 min) the rendering is good enough, but in the background, where the DOF is strong, there is a flickering cause the noise pattern changes every frame.
In VRay we have the option called “Time independent”,
Time independent - when this option is On, the sampling pattern will be the same from frame to frame in an animation. Since this may be undesirable in some cases, you can turn this option Off to make the samping pattern change with time. Note that re-rendering the same frame will produce the same result in both cases.
I tried with CROP with 200 passes, and it looks, obviously, better. But the rendering time will be x4. So, from 40 min, I’ll go to 160 min per frame at 1080p! Maybe this is the only solution: wait! =)
About the scene ok, I clean up it and I’ll send you.
Ok, after some frame at 1280 with high settings (PTS 8 ans 150 passes) flickering still here. Look at the sequence. I don’t know what can I do =(
I think it’s AA problem, but I’m not 100% sure. Sequence.rar (8.05 MB)
You are referring to that noise on grass in the background?
Are these grass clumps the same models as grass in the foreground? I think the problem is there is so much geometry and shadows. Maybe try rendering it with pt+pt, pts 4. There isn’t much visible GI here, you mainly need smooth edges.
Rawalanche, same problem with your setting.
I think this is a limit for Corona =( small objects with hight detail isn’t able to render without flickering.
I’ll make a sample scene fro everyone as soon as I can.
Are you sure it would be possible to render it without noise in vray? There is an animated sun in this scene so there are lots of subtle changes in that distant area. It’s hard to imagine for me not to get animated noise in this case. You would even get noise if you recorded it with a camera in real life.
Ok, I removed animation of sun and camera and now there is completely no noise in each new frame. You have to do the same or make the movement of sun/camera much much slower.
Yes, I know. But it looks like it’s more of a feature than a bug. You can also see it in the grass in the foreground - shadows moving between individual grass blades. Same happens in the background but it’s much more dense. I can’t imagine how this could be overcome in vray or any other renderer.
i would really like to see vray in this scenario. It is impossible to keep the same noise and do the optimal light sampling when lights change. This is not a bug and I cannot fix it…
