Noise level by objects
Hi, an option to choose which objects we want to have a higher noise to speed up the rendering process. For example, in an exterior render tell the engine that the grass or vegetation has a 5 and the rest 2. Thank you
No please, dont want to go back to vray!
I do not understand you. Wow, what does this function have? Can I choose the desired noise level per object?
It means that it would complicate things and could be a base for errors and misconfiguration to introduce additional parameters here and there (and I agree). This should be (already) handled by adaptivity. If not to your satisfaction, it may get improved (which happens constantly during development). Can you show an example (beauty and CInfo_SampingFocus) where it could be handy? Afaik the sampling of dark areas or high detail foliage has been improved a lot in the past (means: using less samples there) but there is always room for improvements.
Good Luck
