I am doing an animation with lots of moving objects in a white space.
I am trying to avoid using GI. My scene is lit using a dome light and an HDRI map. The HDRI map I am using is blurred and reduced in size.
My renders are coming out noisy. I’ve tried raising the light subdivisions to all the way to 300 - it does help a little but its not fixing the issue and the render is crawling. My DMC sample settings are min 1 max 100.
In desperation I have experimented by go down the irradiance gi method. The tenders come out smooth.
In Vray is it possible to get a smooth HDRI lit scene rendered in a timely manner with out GI?
The Dome light is 256 subdivs, Resolution 512 Adaptiveness 1
DMC is min 2 MAX 16 Noise threshold .001
Apart from making the render even slower. I find it makes very little difference upping the DMC max or reducing the Noise threshold or increasing the Light Subdivs etc.
The only thing I have found that smooths out the dome light is to store it with the radiance map and render the scene using GI.
I couldn’t open your max file but I tried setting up a teapot scene with the HDRI;
DMC: 1/4
Dome light: 20 subdivs
Material: 50 subdivs
I get a smooth result. But when I turn the DMC up to something like 1/8 or 2/16 it starts to bring more noise into the image - I then doubled the light subdivs.
check out your render elements; raw reflection (material subdivs), raw lighting (light subdivs), & Sample rate (DMC) - and play with it
In you case it it would be much effective if you use the default Vray settings instead of universal-ones.
Here is one example with Adaptive DMC 1/4 , 16 subdivision of the lights and default DMC sampler settings.
Render-time = 19second and the image is much cleaner than the one with universal-settings.
