Not running on Parallels on Mac M1
I am trying to install the trial version in my Windows 11, in Parallels for my iMac M1. When I try to install the .exe file, it says that the version I have is not supported. What can I do?
Hello @Beto_1
Could you please give a more detailed error message you get?
Which Windows 11 version do you have - the one built for ARM CPUs? In this case you cannot install Enscape because we don’t build it for ARM on Windows.
Moreover, I suspect this configuration will not work because we only support NVidia, AMD and Intel GPUs on Windows.
Enscape doesn’t run in virtualization.
Hi. I understand that Enscape doesn’t run on a virtual machine in a Mac environment. It sounds like the reason is that on the M1 chip, the GPU shares RAM with the CPU. Can anyone explain why that’s an issue? If the combined processor has more than the required 4BG of RAM, what keeps that from doing the job? I’m curious (and frustrated of course, since I can use every other Windows software I’ve tried to work with, but I do get that this requires more graphics work than Rhino and Revit). A primer on GPU CPU Memory would be awesome.
Thanks!
Parallels does not support Vulkan 1.1, which is required to run Enscape.
Any suggestions on mac workflow on Enscape on rhino?
Hello @frederica97
Rhino support for Enscape for Mac is coming with one of the next updates soon.
Hi there!
Is there any beta version of Enscape for Rhino for Mac available?
I’ve recently got M3 pro max and would love to test Enscape on it. Especially because I’m working on a project right now that would be perfect for testing this.
Also, will Enscape make use of the raytracing cores of the m3 max?
Thanks in advance!
Cheers,
Miru
Hi @miruna_vecerdi
Beta version for Rhino should be published this week. It has a few features added towards feature parity with Windows version. But hardware raytracing for Mac is not there yet.
Alex
Hi @Alexander_Devaykin
are there any news on the Beta yet?
Would be great to test it if so :slight_smile:
Cheers
Miru
@miruna_vecerdi
Sure, please have a look at the announcement post:
Thanks @Alexander_Devaykin !
Just tried it and it’s nice to finally see it compatible on Mac with Rhino!!!
Cheers
Miru
