Nurbs Smoothing Problem
Ahoy!
so i have been trying to render a CAD car my brother built and ran into the issue seen in the picture.
Tried it with VRay and the smoothing was rendered as displayed in viewport (sorry i missed out a comparison).
Is this a common issue or am i missing something?
Thanks in advance,
Leif
P.S. : Converting to meshed ends in horrible quality.
is this a “body object”?
Yes, it is known problem. Corona is capable of rendering what is called body objects in 3ds max, with a little workaround. Just change settings of your body object according to attached picture and you’re good to go.
Yes it is a body object.
Thanks for the tip will try out asap :smiley:
I really love this renderer and so far it provided me with really great results, so thanks for the awesome plugin and all the effort and support you get here!
Needed to say that.
EDIT: Sorry i didn’t use search, i’m using max in german so i did not know what to search for.
Worked :smiley:
Body Utility is a real goodie when you have 200 parts and more!
Thank you very much guys, i really appreciate your help!
