nvidia denoiser warning opencl
good morning guys. so yesterday had the bad idea to update my nvidia studio driver for my 2x2080ti cards. now got this message.
using vray next update 3.2. tried with vray 5 and same thing
1.JPG​
Check if the “GPU Device Selection” tool (C:\Program Files\Chaos Group\V-Ray\3ds Max 2021\bin\vray_gpu_device_select.exe) works. If so, the issue may be due to an older OpenCL installation from a third-party plugin. In this case, try backing up and then replacing the “OpenCL.dll” in the 3ds max folder with the one located in the system32 folder (C:\Windows\System32\OpenCL.dll). If not, do tell which Nvidia driver did you install.
