I am wondering if or when other Render Mask Modes will be available in vray 5 for cinema 4d. For example, the Maya version has Object Set, Object IDs, and Isolate Select. 3Ds Max has a similar set of options as well with the addition of Layers.
The Object ID render mask mode is extremely useful and is integral to our workflow, we can batch render many variations of individual objects and save them as a png files with alpha. Then we can comp the object pngs together and quickly visualize many variations of a scene. This is a feature we use heavily in vray 3.7 and I would love to start using vray 5. Are there any suggestions or work arounds to do something like this vray 5? I am hoping someone from Chaos Group can shed some light here.
It is on our to-do list to implement render mask modes: “Selected” and “Object ID”. I’ll make sure to mention this thread and bump its priority additionally. I will let you know when there are any updates on the matter!
I am stoked to start using vray5, all my test so far have been a very positive experience. It is so much faster to setup and render with. I will keep an eye on this thread for when the additional modes are added. Thanks again!
Hello everyone,
please take a look at the video in this post. It explains the difference between the ObjectID and MaterialID Render Elements (render masks) in V-Ray 3 and V-Ray 5 as well as how to use the same masks in V-Ray 5
Yes, my bad I saw this after I made the post, sorry about this.
You can try the Object Select render element. It works the same as the Render Mask and you can render specific objects with alpha masks and then edit them in any compositing app. The only difference is that with the Render Mask you’re rendering only the chosen objects while with the Object Select render element the whole image needs to be rendered from the beginning.
The Render Mask is in our priority list, so I’ll update the thread when we have more information about this.
@shaio
How does the Rendermask currently work? I don’t get any result when switching the render mask from disables to texture and useing an object ID pass from a previous rendering.
Currently, the render mask doesn’t work correctly. This has already been reported in our system (bug ID: VC4D-726). I will let you know once we have any updates on the matter.
We are constantly working on fixing issues, reported by our users. This bug has not yet been fixed. I have boosted its priority and will let you know once we have more information. Thank you for your patience and understanding.
I’m shocked to see that this basic feature is not working. I need to render just a small part of a huge picture and the result is just black. I’m frustrated more and more.
Please fix this soon.
As a workaround you can use a render region, if that is not enough you can use the follow mouse option and “paint” with the buckets only the part you need.
My workaround is to add a small plane with a hole right in front of the camera. @sirio76: you mean the render region in the editor? and I dont know the “paint” option you are describing.
In the past I often needed to render with an animated(!) mask.
In projects with water and ships I used to render simple versions of the ships with the high detailted water and later I re-rendered the whole animation with the animated masks of the ships to avoid re-calulating the water. That was very helpful. Would be great to have this feature again.
The Object ID render mask has not yet been implemented in V-Ray 5 for Cinema4D. Our developers are working hard on fixing existing bugs and implementing new features.
I will make sure to update this thread as soon as we have any news on the matter.
