I’ve been using Corona for a couple of weeks now and I’m really enjoying how well integrated into C4D this render engine is.
I’ve been trying to set-up a basic tree. It is a standard-issue tree rig, with a leaf material that contains an image in the diffuse and a black and white image in the opacity channel. However, once the black and white image is loaded in the opacity channel, render times shoot through the roof. Even a basic scene, with only a ground plane and a single tree is taking around 20-30 minutes on my machine. I’ve attached the basic scene below.
Am I setting this up wrong or is this kind of performance expected with an object like a tree that contains many leaves all with their own opacity channels? Thank you for any help you can send my way.
I was getting an estimated 4 mins on loading the scene. This came down to 1 minute if I used a Corona Bitmap shader in the Opacity rather than the PNG directly in there, and enabled “Clip” for the opacity. (either change on its own also makes a big difference, but combined made the biggest reduction in render time). Hope this helps!
I appreciate the help, Tom. Using the Corona Bitmap shader helped significantly. However, I don’t see a “clip” box below the mix strength slider. I am running Corona A1.6.
