I’ve encountered an issue where the opacity map isn’t working.
I have a Vantage scene with an imported VRScene of a building model and another imported VRScene containing an animated tree model.
The animation and opacity of leaf material perfect in the viewport, but when I switch to the render tab (Ctrl+R), the opacity map disappears on the animated object. I’ve tried different settings in both the material and the render settings. I’ve attached screenshots illustrating the problem. I’m using Vantage 3.0.2.
I haven’t tested whether this issue occurs only with animated objects.
It looks like this is caused by the Medium quality preset selected in the Render UI. It disables clip opacity. You need a higher preset or Custom.
