Opacity maps in render elements
Hello all,
Recently I have started using Vray RT for interactive rendering and started experimenting with possibly using it for production renders. While testing relevant features I noticed some render elements do not consider/inplement opacity maps in their pass. This is holding back Vray RT as a production render quite badly. The render elements in which I experience this problem are the MultiMattaElement, VRayExtraTex_Map (dirtmap) and the ZDepth. It is probably present in more elements but I have not tested them all. The Alpha and Global Illumination elements rendered just fine with the opacity in the same render.
Is there a setting I am forgetting or is this an issue with the renderer itself?
Can you get me an example scene?
Of course, had to build a quick scene due to the problem occuring in a project which I can’t post. Attached the scene and a simple opacity map in the post.
Thanks in advance.
Edit: I’m using 3ds Max 2016 with Vray RT 3.20.02
GPU production test opacity problem.zip (127 KB)
Thanks for the scene - we managed to reproduce the issue.
It is considered as a bug and reported into our bug-tracking system.
Will let you know when we have some updates about it.
Thanks for the help! Looking forward to a fix
Any news on this issue so far? :slight_smile:
We are still looking into it. As soon as we have any update we will let you know.
Been a while since the last update here but is this issue getting nearer to a fix?
Not yet unfortunately. We won’t forget to update this thread when the fix came out.
