Hi, I’m using houdini 19.5.490, I can’t pack vray scene using vray meue - pack scene.
it says: file name, directory name or path syntax are not correct:‘c:/Users/ADMINIC:/User/Adnimistrator/Documents1/APppdata/Local/Temp’
the path it shows indeed are not valid, but I don’t where it get set.
Dear @len_xie , hello.
I was able to reproduce it with latest nightlies.
Thank you for reporting!
TS
Hi again,
The issue has been resolved in our latest nightly builds.
Let’s pack this project now : )
cool! vrayForHoudini is getting better everyday! thanks!
downloaded the latest version(22273 from 05 feb) , but the pack scene shows the same error, even for blank new scene, may be should wait for next build?
Hi again!
I have tested with our latest nightly builds and everything was and is fine, please follow the link that I have attached earlier.
If you are not seeing them (seeing stable section only) - share, and I will give you the needed access.
In latest stables (22273 is the number of Feb 5 stables) the fix wasn’t included indeed, we will add it.
Since we haven’t cleared out in the beginning, are you using Houdini 19.5.403 or Houdini 19.5.493?
You have mentioned 19.5.490 in your initial post, so maybe be there is a miswritten number.
Hi again @len_xie .
Yes, these are stable nightlies, tomorrow stables will include the fix too.
About nightlies access - please open a ticket via our contact form and choose License Management under Request type.
working now thanks!
Great! Thank you for approving.
