(Open) [HOU-4489] Husk: VRay progress update increments
Is there a way to adjust the update frequency of the render logs when using Husk and VRay?
We are using this command to kick off the render: houdini/20.0.724/bin/husk -f 1004 --renderer V-Ray -Va2
This is what we are currently seeing:
[ 2024-11-06 12:38:18 ] : [ Mem : 116.84 GB ] : [2024/Nov/06|12:38:16] V-Ray: Rendering image… 54%
[ 2024-11-06 12:38:18 ] : [ Mem : 116.84 GB ] : [2024/Nov/06|12:38:17] V-Ray: Rendering image… 54%
[ 2024-11-06 12:38:18 ] : [ Mem : 116.84 GB ] : [2024/Nov/06|12:38:17] V-Ray: Rendering image… 55%
[ 2024-11-06 12:38:18 ] : [ Mem : 116.84 GB ] : [2024/Nov/06|12:38:18] V-Ray: Rendering image… 55%
[ 2024-11-06 12:38:18 ] : [ Mem : 116.84 GB ] : [2024/Nov/06|12:38:18] V-Ray: Rendering image… 56%​
Bump. These ultra-granular progress updates make for endless scrolling when trying to debug or locate particular info. Any pointers as to where we can control this are most welcome.. :slight_smile:
We’ll change the behavior to update for each % change in progress during rendering instead of updating at a set time interval. I hope that will help out with the clutter.
Best regards!
Thanks @Gosho.Genchev , I think that would work better. Will there be any way for the user to configure the progress interval (via UI, env var or otherwise), or will it be a hardcoded value?
Hey @Dan_Andersen ,
We decided on hard-coding it to 1% intervals to avoid cluttering the UI. Do you see the need of exposing such a control?
Best regards!
I think it’s a sensible default, so we’re probably fine without the ability to change it. If it turns out to be an issue, I’ll make a new forum post :slight_smile:
