Orthogonal rendering
Hi
I want to render a facade orthogonally for an architectural rendering.
The camera always provides a perspective view.
It works in Cinema and also in earlier Vray versions.
What settings does the Vray 5 camera need.
Rudi
Hi Rudi,
I asked this question only a few days ago. You would need to switch to Orthogonal camera in your settings, and use the VFB to show the final shot. I found that it seems to be connected with the focal point of the camera currently. Point the focal point on the target and then play with the field of view. Hope this helps?
thanks,Mark
Thanks Mark !
That is the solution.
Best regards
Rudi
