I am using max 2024 with Vray 6. I Max I am using the OCIO Color management at default. In the display Correction section Default. I use After effects and Photoshop to comp my work, but when I open the exr in both applications its either blown out or saturated. I’m not sure how to correct this.
HI, thanks for posting. I believe this is what is happening:
The brighter image (the one in linear) is the result from the OCIO correction and in order to view it as in VFB we need to apply sRGB correction.
Try to create an Exposure layer in Photoshop and set the Gamma to 0.45, it should look roughly the same as in VFB.
