Overflow Vray rending, Offering CPU long duration high memory rending on secure private WS and network. Can rendering indefinitely at 100%
Finishing final steps to bring a professional private alternative to render farms. By contract agreements, once agreed, you transfer final render files and get final renders in selected format as well as the .vrimg. Hardware available is Threadripper PRO 5995wx with 256gb ecc 3200MHz rdimm, system is liquid cooled and monitored by AquaSuite. Optimus CPU block with a ekwb radiator cooled by 4 Noctua NF-A14 3000ippc fans. 4 NF-A14 fans for intake these 8 are Aquasuite controlled. 1 NF-A14 exhaust controlled by RAM temp. CPU runs full power at a comfortable 48C on all tests so far, xmrig for 12 hours, Vray renderng Sprite Fright for 8 hours, even ran prime95 for 6 hours with massive cooling headroom on CPU, RAM hot spot sits at 55C max most stay below 50C. Every render is monitored by remote access if not on location, multi scene renders will be loaded with minimal downtime, can deliver finals as they finish or as complete batch. Network is enterprise grade Unifi equipment using Multi Layer architecture isolating the WS on its own VPN network with only a single Wireguard tunnel allowing remote access. Vray License is already purchased, LLC is organized, buisness account and secure payment system in progress once complete we will be accepting work by contract. If this service is of interest please contact us we can give you a better time frame, rough costs for your needs, we are also willing to do some no cost trial renders for serious clients. This will give you actual render time for your work, prove hardware, test the whole process. We also will be offering secure file storage. Archsage LLC. website coming soon. Contact matthew@archsagellc.com if you are interested. Our Vray benchmarks are posted, current system is dialed in at 80k vsamples/min.
Website is up and running. archsagellc.com
