i put one material in override MTL windows after lunch a render C4D crash !!
Does it happen in the same scene again if you repeat the steps? Can you share what the material was that you placed in the material override (a screengrab of that material set up might be good). Does that material work if used in the scene directly rather than via Mtl Override? Does that material in the Mtl Override cause the same crash in other scenes?
I put a simple matter and now it works
thank you ![]()
No repro, no bug. If this happens again to you, feel free to write another bug report.
