In 3Ds Max you can quickly override all geometry in the scene by adding a material in the override slot in the Vray render panel.
I cannot find a way to do the same in Cinema. Am I totally missing something? It should be possible right?
Of course… when you post a question, 5 minutes later, you find the solution I was looking in the wrong location, In the render settings there is the material override checkbox:
