Updated from vray 6.1 to vray 6.10 this weekend.
When 3ds max starts up i get this msg : “./plugins/vrayalmtl2023.dlt” specified in “C:\Users\**\AppData\Roaming\Autodesk\ApplicationPlugins\VRay3dsMax2023\PackageContents.xml” doesn’t exist.
Is this something that can be ignored or …?
Max2023 / Windows 10pro.
Found it strange i was the only one reporting this so there had to be another reason i was getting this popup.
Seems windows defender thought the file “vrayalmtl2023.dlt” is a trojan.
I only have defender running on my workstation, this never happened before. Strange.
I guess its save to whitelist that file?
Did you ever solve this? I’m trying to install VrayFur Styler and I have to add a line of code to the ‘PackageContents.xml.’ The documentation only says to add the line to the list, but gives no tips on how to do it properly.
When I put it in most places I get the error above. When I put the code after everything else, no error, but no modifier either. I just don’t know how to properly insert the code. Any tips?
