Per-instance/per-project color & material overrides for Custom Assets (Adjustable Assets currently excludes them)
Status: new
We run an architecture office with a shared custom asset library on a network drive, used across multiple projects and multiple simultaneous users. We frequently reuse the same custom asset (e.g. a piece of furniture) in different colors across projects.
Today, any color/material change to a custom asset is written into the shared asset file itself. This means:
  • Changing the color in one project retroactively changes it in every other project referencing that asset.
  • With multiple users working at once, this causes constant unintended overwrites of finished work.
I understand Adjustable Assets already solves exactly this problem (non-destructive, per-placement color/material variants) — but only for Enscape’s built-in library, not for Custom Assets.
Request: Extend Adjustable Assets (or an equivalent per-instance override) to Custom Assets, so color/material changes apply per placement/per project without modifying the shared source file. For any office managing a centralized custom asset library across multiple projects and users, this is a real, recurring workflow problem — not an edge case.
Hi @AposTolis_Gkentsidis , thank you for describing the situation so clearly, this helps. Shared library, several projects, several users, and one colour change ending up in every project (or overwriting a colleague’s work) is a real problem, and we hear it from other offices too.
I must be honest, this is not something we can add as a quick extension of Adjustable Assets. The custom asset file is the source today, so a per project change needs a different foundation underneath. We are looking at this in a bigger context (how custom assets are stored, how they are edited and how they’re shared in a company), and as this is a complex topic I can’t promise a date, unfortunately. What I can say is that it is on our list for next year, and I’ll update here once we know more.
One question to understand the scale: roughly how many custom assets are in your library, and do you currently duplicate assets per colour as a workaround, or do you simply avoid it?
Hi @Mehmet_Gunduz1,
Thanks for the honest answer and for confirming it’s on the radar.
To your question: our custom asset library ranges from 20 to 100 assets depending on project size. Most of the time we avoid the use case (we just pick a different asset or keep it in one color rather than risk the conflict), but there are about 5-10 assets where we do duplicate per color because we need that specific piece in multiple colors often enough that avoiding it isn’t practical.
So the duplication is already happening, just capped at the assets where the pain is worst — if per-instance overrides existed, I’d expect that number to grow, since right now we’re actively avoiding a workflow we’d otherwise use.
Looking forward to any updates when you have them.
