Hardware,
- CPU: AMD Ryzen 9 5950X 16-Core 32-Threads
- Motherboard: Asus X570 Crosshair 7 DarkHero
- System Memory: 128 GB DDR4 3200 CL18
- GPUs: RTX 4080, RTX 3080, RTX 2080, GTX 1080
- Bandwidth: PCIe Gen 4.0, x8
- OS: Windows 11 Pro
- Nvidia Studio drivers 536.40
- No monitors attached to the GPU(s)
Testing,
We have tested 4 scenes on this hardware using Progressive mode, the results are double checked. The scene are setup carefully to push the GPUs to 100% usage, to ensure accurate results. All tests run for at least one full minute
- Pascal to Turing shows average 1.6X speedup in CUDA
- Turing to Ampere shows average 2.4x speedup in CUDA and 2.53x in RTX
- Ampere to Ada shows average 1.87x speedup in CUDA and 1.86x in RTX
- We tested the same scenes between the RTX 3090 and RTX 4090, there is 2.15x speedup in CUDA and 2.2x speedup in RTX
First Scene, Gold_Interior
Second scene, Cabinet_01
Third scene, Nutcracker
Fourth scene, Forest_001
Note, this scene includes thousands of leaves and grass objects, and has all shading baked to textures, hence showing a big boost for RTX mode. In most cases CUDA mode should be close to RTX mode in performance
Conclusion,
V-Ray GPU shows very good performance scaling on the latest NVidia GPU generations, nearly doubling the performance every generation.
Best,
Muhammed
