I’ve created a very simple scene - a closed room with only one light.
If I set up a normal spotlight from VIZ all works fine, but when I use a photometric light tha scene is completely black. I’ve even tried to multiply my light with 50000%.
The most important thing about IES Lights is that you must draw to scale … your model isnt … your walls are 413 feet high lolol .. ies are phisically correct lights so must your model be !!
first you should set your max units to a scale .. either inches or feet or mm… and then draw as you would expect the walls to be … 2700 mm for example .. your walls are huge and that is the reason the ies is not working.
Thanks a lot. I think the scale issue will solve a lot of my problems.
In my scene I have set up one light i a completely white room. When rendering the scene has a very white dot on the floor and the rest of the room is very dark. I’ve set my secondary bounces to 0,9 but it only helps a little. Which parameter am I missing?
