“Film gate - specifies the horizontal size of the film gate in milimeters. Note that this setting takes into account the system units configuration to produce the correct result.”
We want to reproduce a Sony F3 (sensor size 23.6 x 13.3 mm). When we set the film gate to 23.6 the perspective is not matching. The Maya units configuration is at default value (cm).
I usually use the film aperture for the sensor size. Be aware the value have to be in inches.
I don’t get the Film gate in the physical camera as there is only 1 dimension and sometime work with special camera that have specific sensor size.
So to match a vray camera to a film sequence shot with the Sony F3 Super35 chip with a 28mm zeiss lens, you simply change the film gate of the vray camera to 23.6 and set the focal length to 28mm, right?
