As the title says it,
I have a plane with Vray displacement modifier and phoenixFD tex on it. Works as expected locally but not showing up on chaos cloud rendering.
I also added a UVW Modifier before the Vray Dislp Mod (I read this suggestion in another forum post), without any success.
Any ideas on what can cause this? Thanks
I’m using 3dsMax2021, Vray5 (5.10.01 build001).
Water not rendering in chaos cloud when using Vray displacement modifier with Phoenix Ocean texture - Chaos Forums
Hey @Ambrozie ,
We haven’t forgotten but we have delayed the answer. Our bad. Still need time to check and looking for some help. BTW can you share a Chaos Cloud job and an example 3ds Max scene? I guess the colleagues will need these.
Thanks,
Vladie
Hi @vladie , thanks. I sent the file to support. Looking forward to your solution.
could i ask, did you ever get a solution for this as i have the same problem ? i would be very grateful …
This has been fixed, we had to verify that it works with a simple setup and it does.
If you still have a problem, it might be related to your specific scene, my advise would be to create a support ticket and the team will look into it.
Let me know if that answers your questions
Best,
Kris
