Guys, I have been reading all the threads on the forum abotu making a good carpet. But still cant do one. Could someone post a step by step on how to do one?? Please!!! Thanks. Here is one I did.
Here is my setting
solid color with noise
displacement map w/bump image
i hope this one will work… make the face into group first before applying diaplacement. this technique was shared one of our filipinos here before and it did really work..
1. make a simple plane say 100cmx 200cm.
2. push pull 1cm
3. choose everything and apply your carpet material (name that material into carpet_diffuse), make it into group
4. create add material (link material), choose that carpet_diffuse material
5. bring up the vray sketchup option editor
6. Under displacement use the following: edge length=2, max subd. 500, amount 1
Thanks alot. Nomar…
This looks much better. I have also changed the overall rendering setting. before I didnt have the emissive setting w/the carpet, btu it turned out some color bleeding there. Very weird!!! but after I changed some settings, now it looks better. Thanks again for your help.
i cant see any of your images artchung??? but i think the problem is solve now…
hows podium??? by the way im archijdsantos remember? if you got more questions ill will try to help…
keep it up…
