Please are there any online chat/helps or anything on licensing issues? Uninstalled everything and installed latest Vray Collection (includes Vray and Phoenix FD) and also installed latest Chaos Group License Server etc.
Now just can´t get it working! From myChaos I can see that ALL THE PRODUCTS ARE ACTIVE, but cannot just get the licensed from the “License Server”. Only shows the old licenses there which can´t be used either.
Restarted everything, internet is available etc etc, but no luck. Licensing any Chaosgroup product is a nightmare, has always been. Don´t get me wrong, love the products but licensing.. oh my f**ing God.
We are sorry for the caused inconvenience.
Could you please do the following in order to clean and re-install the V-Ray Online license server 5.5.3:
1. Please close the Services window in your OS(if it is opened) and uninstall the V-Ray Online license server from your Start menu>Control Panel> Add remove programs
2. Make sure to delete the folder C:\Program Files\Chaos Group\VRLService
3. Go to the folder “C:\Program Files\Common Files\ChaosGroup” and delete all files and folders except “vrlclient.xml”, which is needed.
Please download and install the latest V-Ray Online license server 5.5.3 from our website:
After the installation is completed, please check if the V-Ray Online license server status page “127.0.0.1:30304” is available and you are able to click “Online licensing” >Sign In and enter your credentials.
If the same issue appears, please confirm if you have a running antivirus or network firewall/proxy that might be stopping the online licensing?
Let me know if the above suggestion helped you.
Just to be clear: I upgraded a excisting VRay Next license to Vray Collection and installed a new Vray 5. Is this right? So Vray Collection = Vray 5?
Thank you for your confirmation.
Most probably you are signed in with another account. Could you please send a screenshot of the web page “127.0.0.1:30304”, so I can see which account is activated and what you see there? If you want you can send an e-mail to support@chaosgroup.com, so we can check and investigate your account and licensing issue. Thank you.
Sure sent the screenshot to your support mail.
Thank you, everything works perfectly now! ![]()
Hi, I have the same problem and I’ve already sent an email to the support yesterday, but I hadn’t received answer yet. Please, can you help me? I’m completely stuck at work!
Could you please share your ticket number, if you received an automatic reply, so we can check it? Thank you.
