Point Cloud sRGB
I need to render some pointclouds imported from Autodesk ReCap. When I get them into max they look perfect on screen.
When I render them they look washed out, switching off the sRGB curve in the frame buffer displays the colours correctly There are no lights in my scene
I need to render the scene with other objects created in Max. Is there a way to change the colours in the point cloud or it’s material
I’m using Max 2021 and VRay Next
-Garry
Can you get the RGB channel of the point cloud to run through and output node somehow? You could change the gamma in there to 2.2 or 0.54
Also I can’t get the Pointcloud to stop casting shadows. Even if the light is set to ignore the point cloud it still casts shadows.
If I apply A VRay material to it it’s fine (But I loose the RGB data, which is important).
Is there anyway to keep the RGB and retain the features of a VRay material (properties etc)
Would you have a piece of that PC to share?
I tried to do this a while back but could find no way to get the results I wanted with Vray.
This is an old post about the same issue…still unresolved Point Cloud Rendering - General - Chaos Forum
Hi Lele,
I’ve sent you a link to the Point Cloud.
Sent you the file.
In general you’ll need a “VrayPointCloudColor” texture to pick up the PC color, and then you’ll want to feed that to a V-Ray shader of your choice (VrayMtl, LightMtl, PointParticleMtl).
Any issue with gamma, can then be cured with a CC node, if needs be, after the VrayPointCloudColor texture.
Seemingly, with a v-ray material assigned to the PC, shadowing exclusion from the light works fine as well (i forgot to mention this in the message i sent you.).
Hi Lele,
Thanks for the input that seems like what I need.
However I don’t have “VrayPointCloudColor” so I think that I need VRay 5 to get this to work (I’m still using VRay Next)
This could be the excuse that I need to upgrade.
-Garry
Argh, i didn’t realise that that was the case.
I promise, i wasn’t trying to get you to buy V.5.
Not like i’d be complaining if you did… ^^
Cool that it works now though :slight_smile:
No problem upgrading to VRay 5, it was always going to happen, just a case of when.
Thanks for looking into this for me.
-Garry
I also had washed out colors. I only created a VRayMaterial with VRayPointCloudColor in the Diffuse slot and played arround with the values. In my case (a LAS Pointcloud with RGB values) I got a render which was very near to the viewport colors when I changed the “Output amount” to 1,3 and the “RGB-Offset” to -0,25
