I have a scene with a point cloud loaded in 3ds Max 2023. With VRay6, the point cloud renders as completely black.
Same scene, saved as a 3ds Max 2022 file and rendered with VRay 5 Update 2.1 renders correctly, displaying the color information of the point cloud.
Any idea on how to fix this?
Hi could you send us the scene that is causing you issues here or trough our support contact form ?
I submitted a support ticket. Thanks!
Just to recap, as far as I and @nataylor were able to test the issue has something to do with the scene. I tested the rcp file in a new scene and everything worked.
I’m having the same issue as the OP.
Opened a scene in 3dsMax 2023 with VRay 6 and it renders black. Works fine in 2022 with Vray 5.2.
Seems to be an issue with the PointCloudColor Map in Vray 6: it applies a black texture to the rcp. This is also the case in a new scene setup.
