Pool Balls
Getting ready to play, direct form Corona Render…!
Another scene that would benefit from the new cat eye bokeh effects. :smiley:
Thanks for that but I did not found cat eye bokeh effects, where it is…?
I am Corona for C4D user.
You’ll find it in the Corona camera settings. DOF/Aperture shape. Load you’re custom image there.
Thanks… I will give a try.
You’re welcome!
It’s not possible to simulate cat’s eye bokeh with custom aperture shape, you better should wait till this feature will be ported to C4D.
True that, just pointing out the option to customise the bokeh. I look forward to it being ported.
Hi beanzvision,
I am not seeing any effect in IR or in Render view, did I missed any setting ? Thanks.
It will probably depending on a few settings. Your focal length, aperture size, camera angle/position. In this example I lowered the camera angle, set the focal length to 85mm and moved the camera back till i was happy with the frame. Then opened up the aperture (f-stop) to .05. You’ll just have to play around until you get the desired effect you are after.
Thanks, got it… I think need to set camera angle.
I will try again. Thanks.
