Pool interior with caustics
My second vray interior. 1 direct light, 2 photometric downlights.
The caustics are more visible in the divx animation here:
I found it impossible to get the caustics happening on the bottom of the pool, no matter how many settings I tried. If anyone has had any success with this or has any useful suggestions, I am all ears.
Thanks. Hope you like the images.
i know its faking it, but in an animation i used a standard light that used an animated noise map as a “projector” map. For the noise map, i used fractal noise, adjusted high and low values, and animated the phase value. you could set the projector light to only include the underwater surfaces.
sean
Junglejuz, you seem to be getting light and shadows from the windows onto the bottom of the pool… which is what caustics is.
i saw the animation, when it just starts and the camera shows the pool longitudinally, the light from the windows seems projected on the surface of the water, actually you cannot see the bottom of the pool …
mauarduz
Y’know, in the very first Chaos forum, someone created a scene with a pool and it had real caustics in it. This person even uploaded the scene file, and I remember rendering it myself. Does anyone else remember this?
yes. and he even provided his settings too, in case u couldnt open the scene file.
want me to dig up the scene if i can and post it here?
Yes, Psy - Please!!!
CYM..586 :smile:
or maxer can do it… :frowning:
maybe you’ll want to lower the water line in your pool… if even one person gets in it’s going to overflow :smile:
I did a test with caustics in water. It was pretty easy, but when you place a glass in front of it, the rays that hit the water surface are not direct light anymore, so they will not produce these nice caustic patterns on the floor. To have this, enable generate caustics for the glass, or render without glass first and save the photon map to render with the glass ON.
Here’s my little test (without any glass in between light and water surface):
Cool! There should be an addendum to my Caustics 101 tut to cover turbulent or wavy water.
Flipside:How did you do the water in that test? Did you use Realflow or just a plane/box with noise? Also what were your settings like?
Sketch: maybe you’ll want to lower the water line in your pool… if even one person gets in it’s going to overflow
The pool is actually designed to overflow, hence the drains surrounding the outside of it.
Vlado: Junglejuz, you seem to be getting light and shadows from the windows onto the bottom of the pool… which is what caustics is.
The light at the bottom of the pool is direct light penetrating the surface of the water but I am wanting to get the nice wavy patterns on the bottom from the ripples on the surface.
proces2: i know its faking it, but in an animation i used a standard light that used an animated noise map as a “projector” map.
That’s a good idea for speeding things up but i am still curious as to how to get the real thing. Call me a purist :slight_smile:
flipside: that’s a nice little render. Do you need to use photon mapping to create this result or can I get the same result using an irradiance map? I have tried removing the glass and rendering with both methods but still no caustics. I haven’t had that much experience with photon mapping yet. The renders seem to come out much darker. Anyway, I’m starting to wonder if my water doesn’t have enough turbulence or strength in the bump map. Possibly the water is too deep??
Any more ideas?
I just used a plane with a noise map.
I also used irradiance map, you don’t need GI at all to have caustics. But indeed your bump is not very dense and high, and also the water area lit by the direct light is pretty small, so you probabely don’t see the wavy pattern caustics. Set the caustics multiplier to something very high and try again (use low caustic subdivs in the light properties for fast testrenderings). Also testrender a view where you see more of the pools bottom, because I’m not sure where your caustics would fall.
I’ll try a new test and post it later, something more like in your scene.
Regards,
flipside
Here’s my try:
It wasn’t difficult at all, I just did all normal steps for creating caustics:
-enable it in the caustics rollout (I changed max photons to 15 to get sharper caustics)
-enable generate caustics in the properties for the direct light (system rollout---light settings), subdivs set to 2500 for final rendering
-also turn on refractive GI caustics in the GI rollout to make sure that GI passes the water surface and illuminates the pool.
There is no glass in the windows. If you want that, just render without, save the irradiance map and caustic photon map and set it to reuse these maps. Then render with the windows visible.
regards,
flipside
That’s a real hassle if I want to render an animation. Do the caustics not work properly with the glass in the scene?
Flipside,
considering how much caustics you’re getting on the bottom of the pool, I’m surprised the amount of cautic reflection on the ceiling is quote low.
How much tweaking will you need to do to your settings to get the ceiling caustics as strong as the bottom of the pool?
SunnyC.
Yeah I noticed that too… What you could do is set the caustics multiplier for the ceiling higher, but this also controls the send caustics of the celing. When your ceiling is reflective you can’t use this workaround because the ceiling itsself would also produce new caustics.
This is why I asked a few times for seperate send/recieve caustics parameters, so you can set these parameters better. And also a difference between refractive and reflective caustics (we have this option for GI caustics, but not for normal caustics…). With this you would easily increase the reflective caustics parameter of the water to have more visible caustics on the ceiling/walls.
So again here’s what I would like:
Normal direct caustics:
-refractive: per object or per material send multiplier and recieve multiplier
-reflective: per object or per material send multiplier and recieve multiplier
GI caustics:
But of course when you don’t need these locals, default values are used. In this matter, I really liked finalrenders approach. Global options and per material locals that you could turn on or off and change their values.
Indeed this can be confusing for people who don’t want it, but if you put these options in a seperate rollout (extended or something), they’re not in the way of those who don’t want them.
On the other hand, I think the caustics on the ceiling will never be as strong as the ones on the pools bottom in real life. I don’t know why, but I just never saw such visible reflective caustics on a ceiling of a swimming pool.
Regards,
flipside
I see what you mean. Some separate settings would be nice.
I do recall seeing some pretty serious reflected caustics from swimming pools though. You know the type, it’s a romantic movie, with a couple sitting by the pool side with champagne. Reflected caustics is bouncing off everywhere, particularly onto their faces and bodies.
Real caustics like this would make a static camera animation awesome.
All you need is a good looking pair of guys and girls floating in the pool
and…voila!!! Animation done.
SunnyC
