is it possible to define the path for images? In 3dsMax it is standard, in Maya I didn’t see how to define output the destination.
(Vray 5, Maya 2020.3)
From the render settings tab select Edit - Change “Project image directory”
Ah great, only saw now your answer ![]()
Strange that it is there so hidden
It’s the way it’s controlled in Maya. When using the Maya project path, images are saved relative to that location. Alternatively, you can enter a full absolute path, but moving the project to another machine will require setting this to an existing location.
