I’ve had Vray for maybe 4 months now and I’m just now getting around to playing with progressive path tracing. I glanced over the tutorial for it on the Vray starting page and sadly, I’m not getting the results I would expect to. When my rendering completes, it basically looks incomplete - like maybe the “don’t render final image” box was checked only it wasn’t.
No I don’t have the image to upload for you because I’m posting out of office, but it was a simple empty interior with a grey overide on it rendered to 800x600. Light Cache was set as both primary and secondary GI, I had about 4000 lightcache subdivs and everything else was default.
So for someone who doesn’t give a darn about render times, what does one have to do to get a noise free, unbiased clean image at 800x600 using PPT?
Well, make sure your Lightcache is set to Progressive Path Tracing mode, and I think that you shouldn’t bother on “biased or unbiased”… who cares ? Try playing with sample size (increase it a little - in this case it can’t be called “100% unbiased”, lemme say “90% unbiased” ). This will decrease rendertime.
Sounds like you didnt choose PPT. As just changing to LC/LC isnt enough to activate PPT.
[/quote]
I actually did have the Progressive Path Tracing Option checked Bro. I think the problem was that I only had about 4000 subdivs so when it stopped, it was pretty damn noisy. I didn’t realize that some folks could just throw it way up to 50K and terminate when they were satisfied.
Is there a recommended Sampling method to use while using PPT (fixed, qmc, adaptive) and would adjusting the QMC adaptive amount or global subdivs do anything?
Thank you for clearing that point up because I was getting confused in a hurry. So no AA “Method” is considered during PPT however AA “Filters” are. What other parameters are considered that could have a big impact on the final result, if any?
To speed things up (and to reduce noise) - play with sample size (increase it) and uncheck AA filter. That’s it. Then you may look at the “adaptive amount” in rQMC sampler rollout. The lower - the longer, but less noise.
