PPT
Hi all,
just a question:
i’ve play’d a bit with LC adaptive/directions only,
VRay sun / domelight with VRay sky mapped, subdivs.:5000 sample size:0,
PPT.
this is what i get ppt without adaptive:
and with adaptive:
looks like he dind’t calculate the enviremont light.
when i increase the sample size everything is fine.
ah i’am using 1.49.74
any ideas?
second this!
I meant to ask for a while.
Seems to use direct lighting only, of sorts.
And goes back to normal biasing it a tiny bit.
Maybe it’s not meant for ppt? :sweat_smile:
Lele
yes, for adaptive ppt there has to be sample size. Otherwise there is nothing to adopt to.
:idea: thanks.
i thought it’s there to speed ppt up. :sweat_smile:
its more there to work with LC (not specifically the ppt part of LC) it will put more samples where they are needed to give you a more detailed finished product
You need to have some *non-zero* sample size for the adaptation to work. If you still wish to get an “unbiased” result, check the “Use directions only” option.
will try’d out. thanks :slight_smile:
