Problem with grass
Hi everyone and thank you for reading my question.
I have a little problem with grass texture. Some parts are everywhere, even under the surface and I don’t find the rendering good.
Is it normal ?
file.html (10.7 KB)
I found a part of the solution :
Objects created with the plugin “skatter” have textures names including “…-grass- …” . So grass is applied even on the blades. And the result is messy. Renaming the textures names is a solution.
But the enscape textures type “grass” is still messy and I don’t understand why.
