Problem with live link in 3ds max
Hello everyone, I don’t know if it happened to anyone else but I have been suffering with a continuous problem of loss of sync of the live link camera in 3dsmax, it simply stops tracking and gets stuck at point zero of the world, this happens with all files I do some video rendering test and then I save the max file and open it again and that’s it he lost the connection and I can’t make it return.
Hi josericardo_desouzajunior,
Can you please record a video of the steps that you are making so we can try and reproduce it?
Alexander
what happens is that when I send it to the live link it does not accompany the camera it is stuck in the center of the world I can only move it in vantage it does not synchronize with max the movement of viwport, I can send the file if needed to better analyze what you think ?
Yes, you can send the scene using the chaos help center here(https://support.chaos.com/) and reference this forum topic. Once we receive it I will take a look and report back.
Alexander
seems to be a similar problem when i updated to 1.8.2, even after trying with different files. after reverting back to 1.8.1 Live Link works again
Hi hopkins_architects1,
Which V-Ray and 3ds Max are you using?
Alexander
hi @Alexander.Atanasov I didn’t find how to send the file of = the way you said but I’ll post here the link of one of the scenes is in 3dsmax 22 vray 6
>>>> link >>>>>>>>>>>>>> https://drive.google.com/file/d/1HhfGm5qT-dz1ieXpYeoma-1899jSvWTM/view?usp=sharing
I believe I found what is causing the Live link lost in your file. Before starting Live link make sure that the View to render drop-down in the Render setup window is not locked to an empty entry (this could happen if it was locked to a camera which was later deleted) - https://drive.google.com/uc?id=1lDRp…zXOy5rA3tNAKYp
Alexander
@Alexander.Atanasov Thank you very much for your help!!
