problem with saved .exr file by vray
I have saved .exr directly by vray and I have an error reading the file: “Error reading pixel data from image file …exr. Unexpected tile x coordinate.”
Its over 4gb file and 13000 px wide. I didnt have problems with saving to .exr before but maybe I didnt render this big, only maybe maximum 8000px wide.
Maybe someone had a similar issue ?
Can you provide more details on this issue ? Are you rendering without VFB? Does it happen only with this project or the EXR is unreadable even if you render just a single primitive in that resolution using the default settings?
I have rendered 8 cameras, 2 of them were 13000px wide and rendered without memory frame buffer. The rest was rendered in 4000px wide and with vfb and those are OK. I dont know if its only this project, I will have to check what will happen in a fresh scene and get back to You. Thanks for the reply.
Yes, please, let me know if this has something to do with this particular project.
In the template scene it saved properly, template scene is a start scene I use for all the projects. Although the file size is a lot smaller, maybe its something to do with the file size ? 1.4GB vs 4-5GB
Do you have any render elements added?
Do you have access t our FTP to upload the problematic scene file? If not, please drop us an email to support@chaosgroup.com mail.
