Problems downloading Vray
I’m trying to download the latest version (7-8 times already). it fails every single time and in different browsers
works as it should here
Did you manage to download the desired V-Ray build from our website?
Could you specify the exact version that you are trying to download in order to test the file here?
I will add that I find that downloads from the Chaos site are often extremely slow in comparison to many other sites. I’ve never had a download fail on me though, or be corrupted - just extremely slow.
That’s because the installation is assembled on the fly… I doubt that many other sites do that. With that said, we changed some things recently which should improve this a lot.
Can you email us to vray@chaosgroup.com with your login information so that we can check what’s wrong? As I said above, we made some changes to the download section and while it works fine for our tests, maybe something is not quite right. If worse comes to worse, our support guys will get you the installation in other ways.
Ah, great to hear.
Sorry for the delay… I got it after 10-15 attempts.
The message said it fails to connect to the server or network if I remember well… I downloaded a lot stuff the same day and I only got problems with Vray.
