I discovered a problem with multi/sub materials in vray rt gpu mode. When I render a tree with 2 sub materials in a scene including a blend material with other geometry around, the tree renders only with a white material. When I render the tree in isolation mode (without a blend material in the scene) it renders normal with 2 sub materials. Is this a bug (conflict sub/multi & blend)? In vray rt CPU mode it works fine.
Daniel Krüger
