Problems with .vismat in VRay 1.48.89
Hi, I’m using VRay 1.48.89, I often get into trouble when trying to use .vismat to my object. These following are some examples…
1. I’m trying to load material as usual
2. The .vismat that i want to use is loading properly to the material editor,
When i press the preview button the material will show up, But “M” button on Diffuse color option will suddenly changed to “m”(even when i’m not press the the preview button and straightly to implementing the vismat to the object)
Then, when I try to implementing the vismat to the object, the object will looks to be black
I’m using .vismat for sketchUp that i have get from ASGVIS allready, Am i done something wrong? Help me Please… and Ups… sorry for my English
Re: Problems with .vismat in VRay 1.48.89
Hi Azmizain
This is a known issue. We are working to fix this. Until now you have to relink the texture for the diffuse layer.
So, it’s clear to me now, thanks for your fast reply Master Fpedrogo … then i can’t wait to the Fixed ones… :smile:
