Process priority
Doesnt matter what is 3dsmax’s process priority, with corona’s rendering its act like “High”.
Yes, i know that there is “Low-thread priority” parameter in Devel/debug, but its not working too. I used to do some modeling while vray was doing its job, but its impossible with corona. The only way is to turn off 1 or 2 coporocessors for rendering.
Am i alone with this problem?
PS. Win8, I7, 32 Gb Ram (so its not about RAM)
PPS. Sorry for bad english.
I haven’t had any major trouble/slowdown working in any other applications (CAD 2D/3D, SU, Photoshop, etc) while Corona goes at it. Just to compare, my computer would lag and come to a near stand still while rendering with mr.
As for specs, I’m using:
Dual Xeon E5-2630 @2.3 GHz
16 GB ram
Same problem here. Better situation with VRay.
No answer?
steyin, try to use 3dsmax for modeling or something else while render is on.
Rawalanche, this is exactly what i’m saying: it doesnt work. Even with lowpriority of 3dsmax its impossible to work while render is going.
if setting priority does not help, my best guess is you ran out of memory
Keymaster, its hard to run out of 32 Gb, never used more than 20.
Rawalanche, i have the same problem on second computer, there is Win7 instead of Win8 on main. Everything else works fine, but not second 3dmax.
Same problem here! Even if only 5 gigs of 64 are used by max/corona. Win7 reacts very nice, compared to MR, but every now and then Win7 hangs completely, even the mouse cursor freezes for a few seconds (~10) before I can continue to work. Setting max to low priority doesn´t change a thing, which always does while using MR.
Win 7, max 2014 sp3, no problems at all. I did short recording to show that i could perfectly fine do modeling in second instance of max, should i want to.
Edit: damn, why is embedding not working yet.
That’s the point, i was supposed to use 3ds max while Vray, mental or Final render were working.
