As in the screens attached, when the dialogues are opened which exceed the viewable height, the window becomes ‘detached’ in some way, so you no longer can see the bottom parts.
To reset it the window has to be shrunk then maximised again.
Did test this on different sized monitors to the same effect.
Hi fixeighted,
This is happening because when all advance menus are opened the minimum height for the camera lister is reached and that pushes the entire window. I will log it and will inform you when there is some development. For the time being as a workaround could you try with a hidden windows tray? This way you will get a little bit more pixels and the icons should be visible.
Alexander
Oh it’s really no problem at all…I only noticed by chance and it’s easily reset.
Just thought I’d flag it. I mentioned it in another post and Vladimir asked me to start a post for it, presumably so it could be noted more easily.
I have a 32’’ monitor so not short on screen space anyway ![]()
