Progressive animation rendering...
Hello there,
When i was using Maxwell render for animation projects, i often used to send two renderings in the queue : one at low SL (basically few passes) for the whole anim, then a second one at final SL value in a “resume” mode…
The idea is to get quiclky all the animation frames to be able to start post and montage, while the final frames are rendered. Once the long final render is ok, i just have to tell Nuke / afterFX or so to replace files, and voilà !
I know Corona has a resuming feature, but will it be only within the current scene opened within 3dsmax on the main PC, or can we tell corona render to resume renders via backburner ?
If not, here is the feature request :wink:
Regards
Duplicate: https://forum.corona-renderer.com/ Resume render extended to animation
