Dear V-Ray users,
with our prorender PRM for V-Ray Denoiser tool you can easily accelerate and distribute denoising jobs on your renderfarm. As you can see it in the screen recording video the GUI gives you control of the most important parameters.
Youtube video/link:
https://youtu.be/UKsd3RGMfVQ
With the prorender PRM for V-Ray denoiser tool it’s very easy to submit denoising jobs on a renderfarm.
scope of functions:
-accelerate and distribute V-Ray denoising jobs on a renderfarm
-easy GUI usage with drag’n’drop
-save/load presets for changing vdenoise settings quickly
-works with cost-free backburner render manager
-supports CPU/GPU denoising with CPU fallback mode
If you want to buy the software please use the contact & registration form:
More Infos about the prorender Denoising Cloud Service:
prorender | Renderfarm & Render Service
Looks good,
Is this tool available and if yes, for how much?
Dabarti explained how to do this by hand and for free :
Maybe you used that tutorial to build your tool actually
Cheers
Hi Stan,
the prorender PRM for V-Ray Denoiser tool is available right now.
Software prerequisites:
-Windows 7, 8.1, 10, Server with Microsoft .NET Framework 4 or higher
-Autodesk Backburner
-Chaosgroup V-Ray Denoiser
The tool helps you to accelerate your denoising jobs and has following advantages over a scripting method:
-drag’n’drop and one-click job submission
-flexible & customizable settings of vdenoise parameters with the easy-to-use GUI
-selectable render servers or render server groups for rendering the denoising jobs
-selectable image ranges stillframe, frame list, sequences or step sequences
-suitable for the professional usage
-compact & clear GUI design
-ready-to-use, requires no extra and time consuming scripting knowledges and helps you to focus on your visualization works
-saving extra costs for separate render manager software - Autodesk Backburner comes with Autodesk products
-easy-to-use denoising saves rendering time & hardware costs and helps you to get faster rendering results and therefore increases your profit & competitiveness
prorender | Renderfarm & Render Service:
Please use the google translate button on our website to translate to the required language.
