proxies - relative file paths
hi there,
sorry to bring this up again, but what is the status on relative file paths?
it would be super if it would be supportet and if enscape offers some “help” when maps went missing… maybe it could iterate down the file tree of the current component/proxy location looking for the files?!
anyway - i hope to get some good news on this one since we operate on different machines and networks and it makes no sense to have duped and tripled…
if anyone has a good workflow or file management for custom models proxies and mateiral - lat me know :slight_smile:
best, franza
Hi Franza,
we still don’t have ways to change material paths afterwards automatically or via relative paths.
What I can offer is a proven workflow that can be useed n shared / team projects:
The problem
Enscape uses a bunch of external resources. These are Custom-Assets, Downloaded-Materials, Material-Textures, Skyboxes, Light definitions, Sound files or Linked Sketchup Models.
Depending on your Design Application and storage infrastructure, these external files are not found if you open a project on another PC. This leads to error messages, missing assets and bad material quality (no Height or Roughness Maps and so on). Currently, external resources have to be manually reassigned.
Solution
Accessing external resources on a dedicated mapped drive within a predefined folder structure enables Enscape to load ALL external resources without errors and show the result in original high quality.
The underlying set of folders can be located anywhere on the local computer or on the network. This will work with dropbox, SharePoint and OneDrive, … too. But folders must be keeped on device!
Resources can be shared with externals via structered ZIP files, starting at folder level “EnscapeResources”.
Proposal for a folder structure:
Used drive will be *X:*
Main folder for resources could be #EnscapeResourcesOnX - this one will be mapped to *X:*
inside this the predefined, commonly structured folders are located.
Consiting of the mainfolder EnscapeResources and the following subfolders
  • Custom_Asset_Projects
  • Custom_Assets
  • Downloaded_Enscape_Materials
  • IES
  • Linked_Models
  • Skyboxes
  • Sound_files
  • Textures
Within the Custom Assets -, Textures-, Skyboxes-, Sound_files- and IES folders you can create subfolders for individual projects, if needed. This will help exchanging projects with externals via ZIP files.
To share downloaded native Enscape Assets as well, an EnscapeAssets folder can be included on the level of the EnscapeResources folder. This make sense if Assets should be stored locally and not be downloaded individually on each PC.
Now map the folder as a networkdrive:
  1. Locate your Resource folder (e.g. C:.….….…#EnscapeResourcesOnX) and copy path
  2. Edit path (e.g. in Notepad) and change drive *C:* to *\localhost\C$* (D:\ must be renamed to \localhost\D$) - result should look like \localhost\C$\Users.........\VIZ-Projects#EnscapeResourcesOnX. Copy this to the clipboard.
  3. Inside Windows Explorer go to “This PC” and open “Map network“ drive from the Computer menu.
  4. Map drive X: to the edited path by pasting it from the clipboard.
  5. Now your drive X: shows the content of the mapped path. If you want, you can rename the drive name to something like “Enscape Resources”.
Last step will be setting paths up in Enscape:
  1. Downloaded Materials
  2. Custom Assets Library
  3. Custom Asset Projects source path
And most important:
*Select files like Textures, Skyboxes, IES ,… directly on drive X:*
If you have any feedback or ideas to improve, please let me know.
Seems like a lot of work for a simple request.
hi there,
thanks for the detailed explanation - i guess there is no way around this then :confused:
We are planing to provide a script for this :wink:
That would be a welcome addition. Thank you.
And here it comes ;o)
The ZIP holds the mainfolder “#EnscapeResourcesOnX” with all the subfolders and 2 scripts / BAT files.
Just unzip it somewhere on your machine and run MapFolderAsDriveX.bat. This will automate the process of mapping the folder as drive X:
With the second scrip you can unmap the folder.
To map any other folder as X: - just copy the BAT files to the folder and run it from there.
#EnscapeResourcesOnX - empty.zip (2.88 KB)
How about a script that just lets us use relative paths? That way we can share a project folder with anyone without requiring them to also map as X. Relative paths also enable very efficient variations which mapping as X does not allow.
As far as I know, this is not possible.
Enscape uses absolute paths and with this little hack windows do the job for you:
You can place your data somewhere and by mapping it to X: you can use absolute paths within Enscape
Hi Norbert
Thank you for the option. Need to excuse myself if I am a noob, but for me this whole thing is not clear at all.
I am desperate to move my model on another computer (more powerful) because I have my University submission in a week, and on my computer the model crashes after taking 10minutes to load. This option would definitely help me out, but I need to understand how to actually do it. Is there a video tutorial link? or a link to a different easier stepbystep explanation for basic users like myself?
Kind regards,
hi there,
question, i have moved all my models, textures etc onto a NAS and i have mapped the nas drive as a network drive to “z”
now i also have put the “offline” models on this drive - does this make sense or would it be better to have the assets offline one each pc OR will the speed of the online asset library be increased so far that it makes no difference using the offline library?
and when downloaded, can i force enscape on the others pcs to use this allready downloaded library`? or would i have to download it on each machinen and overwrite the stuff on the network drive?
having your offline Assets on a NAS will be faster, than downloading them each time from the web. Storing them on your internal HDD will be eaven faster.
We use Sharepoint and “Always keep on this device” on each machine to have maximum speed and a shared library. To have a common setup for Enscape, we map this folder on each machine as a networkdrive, so the path to the library will be the same on each machine.
Hi Norbert,
can you explain how this is usable with Dropbox without it having the user in the path?
