Hi How can I adjust the material scale on a proxy ?
Hello Philippe,
Try changing the UV tiling of a texture in the Texture Placement settings. By default Repeat U/V is set to 1x1, you can change this value to adjust texture size:
If you want to control several textures (e.g. Diffuse, Bump, Reflection) at the same time use the UVW Placement texture.
thanks, to understand , if i create uvw texture, do i need to paste it into the several layers diffuse , bump…etc. ? and when i change it in one of them it changes automatically in all the layers where i paste it?
Yes, you need to change Texture Placement in each texture to Type: Mapping Source and paste UVW Placement texture as Instance.
