So this seems to ‘fix’ things but I’m not 100% if it is the proper method. My main problem is that I always try to calibrate my monitors with both software and hardware (custom profile), then when I edit in PS things go crazy due to different settings.
I’m going to run down my list of tests and troubleshooting steps I did below. Hopefully this helps others.
1) Uninstall all unnecessary software and drivers (including Wacom and Spyder.)
2) Remove monitors and hidden monitors (\right-click My Computer\Properties\Hardware\Device Manager\ (click \view\show hidden devices)
3) Remove all Windows color profiles (\settings\advanced\color management\)
4) Reinstall Main Graphics Driver
5) Reboot
6) Reinstall Spyder Software/Driver with latest update from 5/02/09
7) Test problem image.
Testing/Finalizing Image for Proper Output:
1. First thing I noticed is PS assigned ‘Color Settings’ with the new Spyder profile created from fresh install. Working Space is now ‘RGB: Monitor RGB - Plug and Play Monitor-1’ (which is my main Dell monitor custom profiled.)
2. Rest is left default.
3. If you import an image, it will ask ‘What would you like to do?’ If you ‘Assign working RGB: Plug and Play Monitor-1’ (middle choice), the end result will match your render output from Vray. For EXR and HDR, you will want to import then adjust \exposure\gamma to .5 to obtain similar results for matching non floating point images.
4. WARNING: Do not try to ‘Proof’ the colors while in 32 bit working space (HDR or EXR.) Most of the colors will come out extremely dark. Make sure if you ‘Proof Colors’ that you have already converted image down to 8 bit. The ‘Proofing’ shows you what your image will likely look like (for the Web) on a Mac RGB, Windows RGB, and on your Monitor RGB. In fact, I think you shouldn’t ‘Proof’ your colors for the web here as it may just add to the confusion. I am leaving ‘Proof Colors’ unchecked as I just want to work in my current Windows gamut.
5. ‘Save for Web.’ I usually look at 4-up. 4-up or 2-up doesn’t really matter. Just note your ‘Original’ preview in CS4 has an option for ‘Preview:.’ If you select ‘Monitor Color’, this should calibrate to what you see on screen outside of PS. And if you have your ‘Color Settings’ (step #1 above) set to ‘RGB: Monitor RGB - Plug and Play Monitor-1’ in the drop-down, then these should match almost exactly to what you see outside of the ‘Save for Web’ window.
Your image ‘will probably’ look a lot different if you have your ‘Color Settings’ prefernces set to something else such as ‘AdobeRGB’ or ‘sRGB’ - especially if you made and assigned your own custom calibration profile. You obviously don’t want this. The goal is to match your Custom Profile/Gamut/Calibration outside of PS (your real working space) to what you will present your client.
So ideally, you should have selected the ‘Original’ ‘Save for Web’ preview, leave sRGB unchecked, and under ‘Preview’ drop-down choose ‘Monitor Color’ or ‘Use Document Profile.’ This will give you the most accurate original image to reference.
In reality, the ‘Save for Web’ ‘Preview’ is only a preview, and doesn’t itself embed color information into the output. Trying to adjust for the ‘Windows’ or ‘Macintosh’ preview here will only make you go further crazy - I’d ignore these.
‘Optimized’ and ‘Embed Color Profile’ Doesn’t seem to make much difference. Only the latest browsers can read Embedded profiles. It’s probably wise to just leave both of these checked.
If you check ‘convert to sRGB’, your colors will look very saturated in the ‘Save for Web’ preview. It will also look blown out either way if you view the image with ‘Windows Picture and Fax Viewer.’ Windows Picture and Fax Viewer is garbage. However, with ‘convert to sRGB’ unchecked and saved, it will look like the original (correct) in browsers. With it checked and saved, it will look saturated (incorrect) in browsers.
I checked these results across multiple browsers, monitors, and computers. My recommendation for this method is to not rely on Windows Picture and Fax viewer, as well as leaving sRGB OFF (unchecked) upon saving to get matching results.
Method 2:
1. Open image.
2. ‘Assign Profile: sRGB IEC31966-2.1’
3. '\Image\Adjust\Exposure\Gamma Correction: .5 if loading a HDR or EXR
4. Colors will look Desaturated slightly - not original Vray output (incorrect.)
4. ‘Image\Mode\8 Bits Channel\’
5. ‘Save for Web’
6. Select image to save with ‘sRGB’ unchecked. Image previews as same in working view as well as browsers however it remains desaturated (incorrect.) Image looks same as above method (appears saturated) in ‘Windows Picture and Fax Viewer’ (which I said before is garbage.)
7. Select image to save with ‘sRGB’ checked. Image previews as same in working view as well as browsers however is correct to original non-floating point Vray output. It is similar to the ‘proper’ results above. However, the working view and end results do NOT match up by assigning this color profile upon opening document.
I am not recommending this method due to working and final differences.
Method 3:
1. Open image.
2. ‘Assign Profile: sRGB IEC31966-2.1’ with 'and then convert document to working RGB’ checked.
5. ‘Save for Web’
6. Select image to save with ‘sRGB’ unchecked. Image previews as same in working view as well as browsers however it remains desaturated (incorrect.) Image looks OVERLY SATURATED in ‘Windows Picture and Fax Viewer’ now.
7. Select image to save with ‘sRGB’ checked. Image previews as same in working view as well as browsers however is OVERLY SATURATED in both (incorrect.)
I don’t recommend this workflow. You’re not working in the proper color space and it tends to saturate all results.
Method 4:
1. Color Space Preferences reset to North America General Purpose 2 (RGB: sRGB…)
2. Open Image. No Warnings by default.
3. Color is desaturated compared to Vray output.
4. ‘Save for Web’
5. Note now that the original ‘Preview: Monitor Color’ and ‘Use Document Profile’ are now different.
6. ‘Convert to sRGB’ button makes no difference because we are already in this working space.
7. Whenever you export any image in this mode, the images will come out looking saturated compared to working view.
I don’t recommend this method if your monitor is custom calibrated because you’re working view will always look very incorrect compared to what you save for the web. They will not match up.
Summary:
This is assuming your monitor is custom calibrated with a custom color profile.
I tried other methods using sRGB with document opening warnings enabled - each option I chose, none of the working views matched up with output. From my experiments so far, I don’t recommend sRGB.
The only method which seems to be most accurate and reliable so far is Method 1 with sRGB unchecked.
I may try to give this a run through with AdobeRGB later. Your feedback is appreciated.
