Pseudo color and lum/lux values
Pseudo color and lum/lux values in Grayscale/color.
is it possiable with Vray ? or am i using an old version that lacks this feature (1.09).
The Max radiosity ignores Vray light (predictable)…
is there a way to transform a vray scene to lum/lux values WITHOUT CHANGING THE ILLUMINATION CONDITIONS ??
:expressionless:
no one ? so i guess a moderator should move this post to the Wish List Section … :slight_smile:
it does work …you have to activate all your G Buffer channels.. not sure which one’s … i just do them all … well it works in the newer versions…
tnx
Thanks, i’ll try that ..
Ok
now the Max preview works, with all channels on, but is there a way of actually RENDER that image full size, like the original render ?
Thanks anyway ..
yes …just render your image, with it active… works for me. But you are using 1.09 …so im not sure if it works in that version?
